Datasheet Texas Instruments LM3492MHX/NOPB — Даташит
СерияLM3492
МодельLM3492MHX/NOPB
Двухканальный светодиодный драйвер с индивидуальной регулировкой яркости, повышающим преобразователем и быстродействующим регулятором тока 20-HTSSOP от -40 до 125
LM3492/-Q1 Two-Channel Individual Dimmable LED Driver With Boost Converter and Fast Current Regulator datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 31 окт 2016
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM3492MH
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)0.2 A
Iq(Typ)3.6 мА
Package GroupHTSSOP
Package Size: mm2:W x L20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs2
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Power Good,Soft Start,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
TopologyBoost,Boost with Current Sink,Multi-Channel
ТипConverter,Inductive,Linear
Vin(Max)65 В
Vin(Min)4.5 В
Vout(Max)65 В
Vout(Min)5 В
Vref1.25 В
  • Evaluation Modules & Boards: LM3492AR111DEMO
    LM3492 AR111 LED Bulb Replacement Reference Board
  • Evaluation Modules & Boards: LM3492EVAL
    Two Channel Boost Regulator with DHC for LED Backlighting Evaluation Board
  • AN-2192 LM3492 12VAC, 7W LED Driver for AR111 Application (Rev. A)
    PDF, 627 Кб, Версия: A, Файл опубликован: 1 май 2013
    The LM3492 demonstration board included in this package is designed for converting nominal 12VACfrom electronic transformer output to drive seven series connected LEDs at 360mA average current. Theend user can directly light up a LED string through the demonstration board from an electronic transformerto test out the performance. With the demonstration board, the LED string not only runs at
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3492 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3492MHX/NOPB
