Datasheet Texas Instruments SN74LVC157AQDREP — Даташит
СерияSN74LVC157A-EP
МодельSN74LVC157AQDREP
Усовершенствованный продукт Четырехканальный селектор данных/мультиплексор с 2 строками на 1 строку 16-SOIC от -40 до 125
SN74LVC157A-EP datasheet
PDF, 418 Кб, Версия: A, Файл опубликован: 3 май 2004
Pin16
Package TypeD
Package QTY2500
МаркировкаC157AEP
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Количество каналов4
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
Voltage(Nom)2.7,3.3 В
tpd @ Nom Voltage(Max)8.2,7 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments SN74LVC157AQDREP
Публикации по теме
