Datasheet ТI LP2981A-30DBVR — Даташит
| Серия | LP2981A |
| Модель | LP2981A-30DBVR |
Регулятор со сверхнизким падением напряжения, 100 мА, с отключением, допуск 0,75 % 5-SOT-23 от -40 до 125
LP2981 100-mA Ultra-Low Dropout Regulators With Shutdown datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 31 авг 2016
- Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
- 3.6V - 5.5V Input LDO Reference Design for MSP430 (Rev. A)PDF, 110 Кб, Версия: A, Файл опубликован: 14 июн 2010
This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design but may not be as concerned about maintaining the highest possible efficiency or longest battery life. - Low Power 150-mA LDO Linear Regulators. Extended Output Voltage Adjustment RangePDF, 41 Кб, Файл опубликован: 11 июн 1999
The TPS76301 low-dropout (LDO) adjustable linear regulator generates a regulated 1-V output from an input voltage ranging from 3 V to 6 V. The application circuit is based on the application detailed in the TPS76301 data sheet (TI Literature number SLVS181A Figure 21) except for the auxiliary circuit which is shown here in Figure 1. - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - ESR Stability and the LDO RegulatorPDF, 83 Кб, Файл опубликован: 7 май 2002
Choosing an output capacitor for LDO regulators with PNP or PMOS pass element can be difficult to specific ESR requirements. This application note explains why higher ESR capacitors are necessary how to chose them and how to determine whether or not the regulator is stable. - Extending the Input Voltage Range of an LDO RegulatorPDF, 32 Кб, Файл опубликован: 16 авг 2002
This application report explains how to use a FET to overcome the input voltage limitation of a linear regulator. - 3.6V - 5.5V Input LDO with Dual-Level Output Reference Design for MSP430 (Rev. A)PDF, 199 Кб, Версия: A, Файл опубликован: 14 июн 2010
This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design with extended battery life by putting the MSP430 into a low-power state between operating states. - Understanding the Terms and Definitions of LDO Voltage RegulatorsPDF, 197 Кб, Файл опубликован: 21 окт 1999
This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab - Simple Power Solution Using LDOs for the DM365 (Rev. A)PDF, 104 Кб, Версия: A, Файл опубликован: 11 сен 2009
- Ceramic Capacitors Replace Tantalum Capacitors in LDOs (Rev. A)PDF, 44 Кб, Версия: A, Файл опубликован: 13 окт 2006
With the proper considerations ceramic output capacitors can be used with low dropout regulators (LDO) and DC/DC switching converters that require tantulum output capacitors. - Understanding LDO DropoutPDF, 52 Кб, Файл опубликован: 9 май 2005
Not all low dropout (LDO) linear regulator data sheets provide the voltage dropout information needed for all applications. This application report shows a designer how to use an LDO data sheet's specified dropout performance to determine the dropout voltage at other operating conditions. - Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - AN-1815 LDOs Ease the Stress of Start-Up (Rev. A)PDF, 81 Кб, Версия: A, Файл опубликован: 24 апр 2013
The LP38851/52/53 devices with soft-start provide a reliable way to ensure that start-up into highcapacitive loads is uneventful and stress free. - Packaging Limits Range of Linear RegulatorsPDF, 75 Кб, Файл опубликован: 8 май 2010
The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LP2981A (17)
LP2981A30DBVR, LP2981A 30DBVR
