Datasheet Texas Instruments TMS320DM369ZCEF — Даташит
СерияTMS320DM369
МодельTMS320DM369ZCEF
Цифровой медиапроцессор DaVinci 338-NFBGA от 0 до 85
TMS320DM369 Digital Media System-on-Chip (DMSoC) datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 12 июл 2016
Pin338338
Package TypeZCEZCE
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY160160
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка570DM369ZCEF
Width (мм)1313
Length (мм)1313
Thickness (мм).89.89
Pitch (мм).65.65
Max Height (мм)1.31.3
ARM CPU1 ARM9
ARM MHz432 Max.
ApplicationsConsumer Electronics,Industrial Cameras,Security, Video and Imaging, Portable Cameras,Video Surveillance IP Cameras
DRAMLPDDR,DDR2
EMAC10/100
I2C1
Operating SystemsLinux
Рабочий диапазон температурот -40 до 85,0 до 85 C
Pin/Package338NFBGA
SPI5
UART2 SCI
USBUSB2.0 HS OTG
Video Acceleration1 MJCP,1 HDVICP
Video Port1 Dedicated Input,1 Dedicated Output Configurable
Video Resolution/Frame Rate1080P,30 FPS or less
  • Evaluation Modules & Boards: TMDXEVM368
    TMS320DM36x Evaluation Module
  • TMS320DM36x SoC Architecture and Throughput
    PDF, 5.8 Мб, Файл опубликован: 29 июл 2009
    This application report provides information on the DM36x throughput performance and describes the DM36x System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of different peripherals on the So
  • Converting single-ended video to differential video in single-supply systems
    PDF, 212 Кб, Файл опубликован: 16 сен 2011
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM369ZCEF
