Datasheet Texas Instruments DAC121S101WGRLV — Даташит
СерияDAC121S101QML-SP
МодельDAC121S101WGRLV
12-битный микромощный цифро-аналоговый преобразователь с выходом Rail-to-Rail 10-CFP от -55 до 125
DAC121S101QML-SP Radiation Hardened 12-Bit Micro Power Digital-to-Analog Converter With Rail-to-Rail Output datasheet
PDF, 887 Кб, Версия: F, Файл опубликован: 29 июл 2016
5 предложений от 5 поставщиков
, DAC121S101QML 12Bit Micro Power Digital-to-Analog Converter with Rail-to-Rail Output
DAC121S101WGRLV
196 077 ₽
DAC121S101WGRLV
DAC121S101WGRLV
DAC121S101WGRLV
Pin1010101010
Package TypeNACNACNACNACNAC
Industry STD TermCFPCFPCFPCFPCFP
JEDEC CodeR-CDFP-GR-CDFP-GR-CDFP-GR-CDFP-GR-CDFP-G
Package QTY5454545454
МаркировкаWGRLV Q5962R0722602VZA >TDAC121S10102VZA ACO
Width (мм)6.1216.1216.1216.1216.121
Length (мм)6.8586.8586.8586.8586.858
Thickness (мм)1.7781.7781.7781.7781.778
Pitch (мм)1.271.271.271.271.27
Max Height (мм)2.342.342.342.342.34
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
АрхитектураString
DAC Channels1
DNL(Max)1 +/-LSB
Gain Error(Max)1 %FSR
INL(Max)8 +/-LSB
InterfaceSPI
Рабочий диапазон температурот -55 до 125,25 C
Output Range Max.5.5 мА
Тип выходаBuffered Voltage
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)0.52 mW
RatingSpace
Reference: TypeExt
Разрешение12 Bits
Sample / Update Rate1.8 MSPS
Время установления12.5 µs
RoHSSee ti.com
  • Evaluation Modules & Boards: DAC121S101CVAL
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
На английском языке: Datasheet Texas Instruments DAC121S101WGRLV
