Datasheet Texas Instruments SN74LVC16T245DGGR — Даташит
СерияSN74LVC16T245
МодельSN74LVC16T245DGGR
16-битный приемопередатчик с двойной шиной питания и настраиваемым сдвигом уровня/преобразованием напряжения 48-TSSOP от -40 до 85
SN74LVC16T245 16-bit Dual-Supply Bus Transceiver With Configurable Level-Shifting / Voltage Translation and Tri-State Outputs datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 28 апр 2015
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVC16T245
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Voltage Level Translation > Direction Controlled Voltage Translation
На английском языке: Datasheet Texas Instruments SN74LVC16T245DGGR
