Datasheet ТI TLV2544CPW — Даташит
СерияTLV2544
МодельTLV2544CPW
Datasheet Texas Instruments TLV2544CPW
12-разрядный АЦП, 200 тыс.
2.7-V to 5.5-V 12-Bit 200 KSPS 4-/8-Channel Low-Power Serial Converters datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 3 июн 2003
импульсов в секунду, сер. Выход, автоматическое подключение (S/W и H/W), низкое энергопотребление с 8 x FIFO с 4 каналами. 16-ТССОП от 0 до 70
  • Interfacing the TLV2544/TLV2548 ADC to the TMS320C5402 DSP (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 26 окт 2000
    This application report presents a hardware and software solution for interfacing the TLV2544/TLV2548 12-bit, 200-ksps, 4-/8-channel, low-power, serial analog-to-digital converters to the 16-bit, fixed-point TMS320C5402 DSK.
  • Thermistor Temperature Transducer to ADC Application
    PDF, 74 Кб, Файл опубликован: 22 сен 2000
    An interchangeable-thermistor temperature-measurement application is described and a basic framework circuit which can be modified to use alternative components is provided. When a potentiometer is used instead of a thermistor, the application can also be used to measure other process variables. A basic understanding of active and passive analog devices is assumed.
  • Pressure Transducer to ADC Application
    PDF, 78 Кб, Файл опубликован: 4 окт 2002
    A range of bridge-type transducers can measure numerous process variables. This report describes a pressure transducer and a bridge transducer to measure strain in mechanical elements. It gives an example circuit from which to implement other applications.
  • Interfacing the TLV2544/TLV2548 ADC to the TMS320C31 DSP
    PDF, 579 Кб, Файл опубликован: 6 окт 2000
    This application report presents a hardware and software solution for interfacing the TLV2544/TLV2548 12-bit, 200Ksps, 4/8-channel, low-power, serial, successive approximation register (SAR) analog-to-digital converters (ADC) to the 32-bit floating point TMS320CX digital signal processor (DSP) through the use of the TMS320C31 DSP starter kit (DSK).A digital-to-analog converter (DAC) interface
  • Evaluating the TLV2462 and TLV2772 as Drive Amps for the TLV2544/TLV2548 ADC
    PDF, 63 Кб, Файл опубликован: 26 июн 2000
    This report presents a method for comparing the ac performance of the TLV2462 and TLV2772 operational amplifiers to the ac performance of the TLV2544/TLV2548 analog-to-digital converter.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV2544CPW
Политика конфиденциальности
