Datasheet Texas Instruments OPA567AIRHGRG4 — Даташит
СерияOPA567
МодельOPA567AIRHGRG4
Rail-to-Rail ввод-вывод, усилитель мощности 2 А 12-VQFN от -55 до 125
Rail-to-Rail I/O, 2A Power Amplifier datasheet
PDF, 826 Кб, Версия: A, Файл опубликован: 20 сен 2005
Pin1212
Package TypeRHGRHG
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаOPA567AI
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм)11
Max Height (мм)11
Additional FeaturesAdj Current Limit,Shutdown
АрхитектураFET
CMRR(Min)60 дБ
CMRR(Typ)80 дБ
GBW(Typ)1.2 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)6 мА
Iq per channel(Typ)3.4 мА
Количество каналов1
Offset Drift(Typ)1.3 uV/C
Output Current(Typ)2200 мА
Package GroupVQFN
Package Size: mm2:W x L12VQFN: 25 mm2: 5 x 5(VQFN) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)1.2 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA567 (4)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA567AIRHGRG4
