Datasheet Texas Instruments TL1451ACPWRG4 — Даташит
СерияTL1451A
МодельTL1451ACPWRG4
Двухканальный контроллер с широким диапазоном входного напряжения 16-TSSOP от -20 до 85
Dual Pulse-Width-Modulation Control Circuits datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 13 мар 2002
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаT1451A
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Duty Cycle(Max)100 %
Iout(Max)3 A
Iq(Typ)1.7 мА
Рабочий диапазон температурот -20 до 85,-40 до 125 C
Package GroupTSSOP
Special FeaturesN/A
Switch Current Limit(Min)3 A
Switching Frequency(Max)500 kHz
Switching Frequency(Min)50 kHz
TopologyBoost,Buck,Flyback,Forward,Inverting,SEPIC
ТипController
Vin(Max)50 В
Vin(Min)3.6 В
Vout(Max)50 В
Vout(Min)1 В
  • Evaluation Modules & Boards: TL1451AEVM-166
    Dual PWM Control Circuit
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments TL1451ACPWRG4
