Datasheet Texas Instruments LM10CWMX/NOPB — Даташит
СерияLM10
МодельLM10CWMX/NOPB
Операционный усилитель и источник опорного напряжения 14-SOIC от 0 до 70
Datasheet LM10
PDF, 3.2 Мб, Версия: E, Файл опубликован: 30 окт 2015, Страниц: 37
Operational Amplifier and Voltage Reference
Pin14
Package TypeNPA
Package QTY1000
МаркировкаLM10CWM
Width (мм)7.498
Length (мм)8.992
Thickness (мм)2.301
Max Height (мм)2.65
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)90 дБ
CMRR(Typ)102 дБ
GBW(Typ)0.05 МГц
Input Bias Current(Max)20000 pA
Iq per channel(Max)0.4 мА
Iq per channel(Typ)0.27 мА
Количество каналов1
Offset Drift(Typ)2 uV/C
Output Current(Typ)20 мА
Package Size: mm2:W x L14SOIC: 93 mm2: 10.325 x 8.9915(SOIC) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.2 V/us
Total Supply Voltage(Max)45 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.1 +5V=5, +/-5V=10
Vn at 1kHz(Typ)50 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • AN-300 Simple Circuit Detects Loss of 4-20 mA Signal (Rev. B)
    PDF, 241 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Four-to-twenty milliampere current loops are commonly used in the process control industry. They takeadvantage of the fact that a remote amplifier can be powered by the same 4-20 mA current that it controlsas its output signal, thus using a single pair of wires for signal and power. Circuits for making 4-20 mAtransmitters are found in the LM10, LM163, and LH0045 data sheets.
  • AN-211 New Op Amp Ideas (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 6 май 2013
    An op amp and voltage reference capable of single supply operation down to 1.1V is introduced.Performance is uncompromised and compares favorably with standard, state-of-the-art devices. In adeparture from conventional approaches, the circuit can operate in a floating mode, powered by residualvoltages, independent of fixed supplies. A brief description of the IC design is given, but emphasis
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • Applying a New Precision Op Amp
    PDF, 421 Кб, Файл опубликован: 4 окт 2004
  • Using ADC0808/809 8-Bit uP Compble ADCs w/8-Chan Analog Multiplexr (Rev. B)
    PDF, 1.4 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application note discusses the use of the ADC0808/ADC0809 Data Acquisition Devices (DAD) withan 8-channel analog multiplexer.
  • Audio Applications of Linear Integrated Circuits
    PDF, 272 Кб, Файл опубликован: 2 май 2004
  • AN-288 System-Oriented DC-DC Conversion Techniques (Rev. B)
    PDF, 833 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation of system-oriented DC-DC conversion techniques.
Серия: LM10 (5)
На английском языке: Datasheet Texas Instruments LM10CWMX/NOPB
