Datasheet Texas Instruments UC3823NG4 — Даташит
СерияUC3823
МодельUC3823NG4
Высокоскоростной ШИМ-контроллер 16-PDIP от 0 до 70
High Speed PWM Controller datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 5 авг 2009
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаUC3823N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCurrent,Voltage
Duty Cycle(Max)85 %
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Gate Drive(Typ)1.5 A
Package GroupPDIP
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)8.4 В
  • U-131 Simple Switchmode Lead-Acid Battery Charger
    PDF, 206 Кб, Файл опубликован: 5 сен 1999
    Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC3823 (5)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3823NG4
