Datasheet Texas Instruments 5962-8780401DA — Даташит
СерияSN54AS21
Модель5962-8780401DA
Двойные логические элементы положительного И с 4 входами 14-CFP от -55 до 125
Datasheet
TSP
Pin14
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)5.97
Length (мм)9.21
Thickness (мм)1.59
Max Height (мм)2.03
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
Серия: SN54AS21 (4)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59628780401DA, 5962 8780401DA
На английском языке: Datasheet Texas Instruments 5962-8780401DA
