Datasheet Texas Instruments DAC2904Y/250G4 — Даташит
СерияDAC2904
МодельDAC2904Y/250G4
Двухканальный 14-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 48-TQFP от -40 до 85
Dual, 14-Bit, 125 MSPS Digital-to-Analog Converter datasheet
PDF, 885 Кб, Версия: C, Файл опубликован: 14 окт 2004
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
МаркировкаDAC2904Y
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels2
InterfaceParallel CMOS
Interpolation1x
Package GroupTQFP
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Power Consumption(Typ)310 mW
Разрешение14 Bits
SFDR80 дБ
Sample / Update Rate125 MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC2904Y/250G4
