Datasheet Texas Instruments UCC3588D — Даташит
СерияUCC3588
МодельUCC3588D
5-битный программируемый выходной BiCMOS понижающий контроллер источника питания 16-SOIC от 0 до 70
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • DN-105 UCC3588 5-Bit Programmable Output BiCMOS Power-Supply Controller, EVM
    PDF, 62 Кб, Файл опубликован: 5 сен 1999
    The UCC3588 voltage mode synchronous step down (buck) controller provides the functionality required for high efficiency, low cost, regulated power for microprocessors. A 5-bit DAC provides output voltage adjustment from 1.3 to 3.5 volts. High efficiency is obtained through the use of synchronous rectification. Tight transient response is obtained through high speed window comparators which bypass
Серия: UCC3588 (6)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments UCC3588D
