Datasheet Texas Instruments TLC2654CN — Даташит
СерияTLC2654
МодельTLC2654CN
Малошумящий операционный усилитель со стабилизацией прерывания 14-PDIP 0–70
Advanced LinCMOS Low-Noise Chopper Stabilized Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 25 апр 2001
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаTLC2654CN
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesZero Drift
АрхитектураCMOS
CMRR(Min)105 дБ
CMRR(Typ)125 дБ
GBW(Typ)1.9 МГц
Input Bias Current(Max)60 pA
Iq per channel(Max)2.4 мА
Iq per channel(Typ)1.5 мА
Количество каналов1
Offset Drift(Typ)0.01 uV/C
Output Current(Typ)3 мА
Package GroupPDIP
Rail-to-RailIn to V-,Out
Slew Rate(Typ)2.8 V/us
Total Supply Voltage(Min)4.6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)23 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.02 мВ
  • DC Parameters: Input Offset Voltage
    PDF, 295 Кб, Файл опубликован: 27 мар 2001
    The input offset voltage, VIO, is a common dc parameter in operational amplifier (op amp) specifications. This report aims to familiarize the engineer by discussing the basics and modern aspects of VIO by providing a definition and a detailed explaination of causes of VIO for BJT, BiFET, and CMOS devices. Discussion centers around measurement techniques, data sheet specifications, and the effect o
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
На английском языке: Datasheet Texas Instruments TLC2654CN
