Datasheet Texas Instruments TPS54618RTET — Даташит
СерияTPS54618
МодельTPS54618RTET
Входное напряжение от 2,95 В до 6 В, ток 6 А, синхронный понижающий преобразователь SWIFT™ 16-WQFN от -40 до 150
TPS54618 2.95-V to 6-V Input, 6-A Output, 2-MHz, Synchronous Step-Down SWIFT Switchertitle of data sheet datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 25 ноя 2014
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка54618
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)6 A
Iq(Typ)0.25 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupWQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking,UVLO Adjustable
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.95 В
Vout(Max)4.5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS54618EVM-606
    Evaluation Module for TPS54618 Synchronous Step-Down SWIFTВ™ DC/DC Converter
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Designing Type III Compensation for Current Mode Step-Down Converters (Rev. A)
    PDF, 298 Кб, Версия: A, Файл опубликован: 15 сен 2010
    One of the well-known benefits of current-mode control is that the system stability can be easily achieved by Type II compensation design. It is possible to improve the transient response of a current mode DC/DC converter by adopting Type III compensation to boost the crossover frequency and phase margin. Type III compensation is simple to design and needs only one extra component.
  • Intel VR11.1 Server Reference Design
    PDF, 38 Кб, Файл опубликован: 21 июл 2010
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54618 (2)
На английском языке: Datasheet Texas Instruments TPS54618RTET
