Datasheet Texas Instruments ADC08D1520CIYB/NOPB — Даташит
Серия | ADC08D1520 |
Модель | ADC08D1520CIYB/NOPB |
8-разрядный аналого-цифровой преобразователь (АЦП) с двойным 1,5-GSPS или одинарным 3,0-GSPS 128-HLQFP от -40 до 85
ADC08D1520 Low Power, 8-Bit, Dual 1.5 GSPS or Single 3.0 GSPS A/D Converter datasheet
PDF, 886 Кб, Версия: D, Файл опубликован: 14 мар 2013
Pin | 128 | 128 |
Package Type | NNB | NNB |
Industry STD Term | HLQFP | HLQFP |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 60 | 60 |
Carrier | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) |
Маркировка | ADC08D1520 | CIYB |
Width (мм) | 20 | 20 |
Length (мм) | 20 | 20 |
Thickness (мм) | 1.4 | 1.4 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1.6 | 1.6 |
# Input Channels | 2,1 |
Analog Input BW | 2000 МГц |
Архитектура | Folding Interpolating |
DNL(Max) | 0.15 +/-LSB |
DNL(Typ) | 0.15 +/-LSB |
ENOB | 7.4 Bits |
INL(Max) | 0.3 +/-LSB |
INL(Typ) | 0.3 +/-LSB |
Input Buffer | Yes |
Input Range | 0.87 Vp-p |
Interface | Parallel LVDS |
Package Group | HLQFP |
Package Size: mm2:W x L | 128HLQFP: 484 mm2: 22 x 22(HLQFP) PKG |
Power Consumption(Typ) | 2000 mW |
Rating | Catalog |
Reference Mode | Int |
Разрешение | 8 Bits |
SFDR | 58 дБ |
SINAD | 46.5 дБ |
SNR | 46.8 дБ |
Sample Rate(Max) | 1500,3000 MSPS |
- Evaluation Modules & Boards: ADC08D1520RB
The ADC08D1520RB: Low-Power, 8-Bit, Dual 1.5 GSPS or Single 3.0 GSPS A/D Converter Reference Board
- AN-1558 Clocking High-Speed A/D Converters (Rev. B)PDF, 1.2 Мб, Версия: B, Файл опубликован: 1 май 2013
Extremely high-speed ADCs (>1 GSPS) demand a low-jitter sample clock in order to preserve signal-tonoiseratio (SNR). These 8- and 10-bit converters have best-case noise floors set by quantization noise.For an N-bit ADC sampling a full-scale sinusoid, the well known expression for SNR (in dB) is: SNR =6.02N + 1.76. This sets the best case noise floor for an 8-bit ADC at в€’49.9 dBc. The noise f
Серия: ADC08D1520 (2)
- ADC08D1520CIYB ADC08D1520CIYB/NOPB
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
