Datasheet Texas Instruments 5962-88522012A — Даташит
СерияSN54AS808B
Модель5962-88522012A
Шестнадцатеричный 2 входа и драйверы 20-LCCC от -55 до 125
Hex 2-Input And Drivers datasheet
PDF, 608 Кб, Версия: C, Файл опубликован: 1 янв 1995
Микросхема Логический чип, AND Gate 6Element 2IN Bipolar 20Pin CLLCC Tube
5962-88522012A
2 913 ₽
5962-88522012A
3 597 ₽
596288522012A
5962-88522012A
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.013 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)-2/20 мА
Тип выходаTTL
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
tpd @ Nom Voltage(Max)6.5 нс
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Introduction to Logic
  • Live Insertion
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
596288522012A, 5962 88522012A
На английском языке: Datasheet Texas Instruments 5962-88522012A
