Datasheet ТI LM3421Q1MHX/NOPB — Даташит
СерияLM3421-Q1
МодельLM3421Q1MHX/NOPB
Datasheet Texas Instruments LM3421Q1MHX/NOPB
N-канальные контроллеры для драйверов светодиодов постоянного тока 16-HTSSOP от -40 до 125
LM342x/-Q1 N-Channel Controllers for Constant-Current LED Drivers datasheet
PDF, 2.5 Мб, Версия: F, Файл опубликован: 4 ноя 2014
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Semiconductors > Power Management > LED Driver > Automotive LED Driver
На английском языке: Datasheet Texas Instruments LM3421Q1MHX/NOPB
Публикации по теме
Политика конфиденциальности
