Datasheet Texas Instruments THS1030IPWRG4 — Даташит
СерияTHS1030
МодельTHS1030IPWRG4
10-разрядный АЦП, 30 MSPS, одноканальный, комп.
3-V to 5.5-V 10-Bit, 30 MSPS CMOS Analog-to-Digital Converter (Rev. E)
PDF, 1.1 Мб, Версия: E, Файл опубликован: 30 окт 2003
с TLC876, индикатором выхода за пределы диапазона, PowerDown 28-TSSOP от -40 до 85
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTJ1030
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
# Input Channels1
Analog Input BW(MHz)150
Approx. Price (US$)6.94 | 100u
АрхитектураPipeline
DNL(Max)(+/-LSB)1
ENOB(Bits)7.8
INL(Max)(+/-LSB)2
Input Range2V (p-p)
InterfaceParallel CMOS
Operating Temperature Range(C)-40 to 85
0 to 70
Package GroupTSSOP
Package Size(mm2=WxL)28TSSOP: 62 mm2: 6.4 x 9.7
Power Consumption(Typ)(mW)150
Reference ModeInt
Ext
Resolution(Bits)10
SFDR(dB)53
SINAD(dB)48.6
SNR(dB)49.4
Sample Rate (max)(SPS)30MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527, which is capable of sampling up to 210 MSPS. To realize the full potential of thes
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the refe
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed, high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483, which is capable of
    As system bandwidths have increased, an accurate estimate of the noise contribution for each element in the signal channel has become increasingly important. Many designers are not, however, particula
  • Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
На английском языке: Datasheet Texas Instruments THS1030IPWRG4
