Datasheet Texas Instruments LMH6629 MDC — Даташит
СерияLMH6629
МодельLMH6629 MDC
Сверхмалошумящий высокоскоростной операционный усилитель с отключением 0-DIESALE от -40 до 85
LMH6629 Ultra-Low Noise, High-Speed Operational Amplifier with Shutdown datasheet
PDF, 9.2 Мб, Версия: I, Файл опубликован: 5 дек 2014
Package TypeY
Package QTY400
2nd Harmonic88 dBc
3rd Harmonic74 dBc
@ MHz1
Acl, min spec gain4 V/V
Additional FeaturesDecompensated
АрхитектураBipolar,Voltage FB
BW @ Acl900 МГц
CMRR(Min)82 дБ
CMRR(Typ)87 дБ
GBW(Typ)4000 МГц
Input Bias Current(Max)23000 pA
Iq per channel(Max)16.7 мА
Iq per channel(Typ)15.5 мА
Количество каналов1
Offset Drift(Typ)0.45 uV/C
Output Current(Typ)250 мА
Package GroupSOT-23,WSON
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23),See datasheet (WSON) PKG
Rail-to-RailNo
Slew Rate(Typ)1100 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)0.69 нВ/rtГц
Vn at Flatband(Typ)0.69 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.78 мВ
  • Evaluation Modules & Boards: LMH6629SDEVAL
    Evaluation Board for the LMH6629
  • Evaluation Modules & Boards: LMH730316
    LMH730316 Evaluation Board for High-Speed Single Op Amp in the 5-/6-Pin SOT-23 Package
  • AN-1604 Decompensated Operational Amplifiers (Rev. B)
    PDF, 206 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application report discusses the what, why, and where of decompensated op amps. This applicationreport also describes external compensation techniques, such as reducing loop gain, to stabilize op ampsoperated at gains less than the minimum stable gain specified in the datasheet. A comprehensivetreatment of input lead-lag compensation including examples is presented.
  • OA-14 Improving Amplifier Noise for High 3rd Intercept Amplifiers (Rev. F)
    PDF, 594 Кб, Версия: F, Файл опубликован: 1 май 2013
    This application report discusses improving Amplifier Noise for High 3rd Intercept Amplifiers.
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
  • Considerations for High-Gain Multistage Designs
    PDF, 347 Кб, Файл опубликован: 13 май 2013
На английском языке: Datasheet Texas Instruments LMH6629 MDC
