Datasheet Texas Instruments SN98212P — Даташит
| Серия | MC1458 |
| Модель | SN98212P |
Двойной операционный усилитель общего назначения 8-PDIP
Dual General-Purpose Operational Amplifiers. datasheet
PDF, 764 Кб, Версия: C, Файл опубликован: 4 авг 2010
DUAL GENERAL-PURPOSE OPERATIONAL AMPLIFIERS | |||
| SN98212P | по запросу | ||
| SN98212P Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Additional Features | N/A |
| Approx. Price (US$) | 0.13 | 1ku |
| Архитектура | Bipolar |
| CMRR(Min)(dB) | 70 |
| CMRR(Typ)(dB) | 90 |
| GBW(Typ)(MHz) | 1 |
| Input Bias Current(Max)(pA) | 500000 |
| Iq per channel(Max)(mA) | 2.8 |
| Iq per channel(Typ)(mA) | 1.5 |
| Number of Channels(#) | 2 |
| Operating Temperature Range(C) | 0 to 70 |
| Output Current(Typ)(mA) | 45 |
| Package Group | PDIP |
| Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
| Rail-to-Rail | No |
| Rating | Catalog |
| Slew Rate(Typ)(V/us) | 0.5 |
| Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 30 |
| Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 10 |
| Vn at 1kHz(Typ)(nV/rtHz) | 30 |
| Vos (Offset Voltage @ 25C)(Max)(mV) | 6 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Understanding Operational Amplifier SpecificationsPDF, 273 Кб, Файл опубликован: 13 июл 1998
Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen - Handbook of Operational Amplifier Applications (Rev. B)PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
Серия: MC1458 (9)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
