Datasheet Texas Instruments LF347DRG4 — Даташит
СерияLF347
МодельLF347DRG4
Счетверенный операционный усилитель общего назначения с JFET-входом 14-SOIC 0–70
LF347, LF347B JFET-Input Quad Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 31 мар 2016
Pin14
Package TypeD
Package QTY2500
МаркировкаLF347
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)70 дБ
CMRR(Typ)100 дБ
GBW(Typ)3 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)2.75 мА
Iq per channel(Typ)2 мА
Количество каналов4
Offset Drift(Typ)10 uV/C
Output Current(Typ)31 мА
Rail-to-RailIn to V+
Slew Rate(Typ)13 V/us
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)18 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Get Fast Stable Response From Improved Unity-Gain Followers
    PDF, 107 Кб, Файл опубликован: 2 окт 2002
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
  • Get More Power Out of Dual or Quad Op-Amps
    PDF, 91 Кб, Файл опубликован: 2 окт 2002
На английском языке: Datasheet Texas Instruments LF347DRG4
