Datasheet Texas Instruments SN74AUC16244GQLR — Даташит
СерияSN74AUC16244
МодельSN74AUC16244GQLR
16-битный буфер/драйвер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
16-Bit Buffer/Driver With 3-State Outputs datasheet
PDF, 830 Кб, Версия: E, Файл опубликован: 28 фев 2008
Pin56
Package TypeGQL
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Width (мм)4.5
Length (мм)7
Thickness (мм).75
Max Height (мм)1
Рекомендуемая замена
ReplacementSN74AUC16244ZQLR
Replacement CodeP
Approx. Price (US$)1.00 | 1ku
Bits(#)16
F @ Nom Voltage(Max)(Mhz)250
ICC @ Nom Voltage(Max)(mA)0.02
Тип входаCMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-9/9
Тип выходаCMOS
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L (PKG)56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR)
Schmitt TriggerNo
Technology FamilyAUC
VCC(Max)(V)2.7
VCC(Min)(V)0.8
Voltage(Nom)(V)0.8
1.2
1.5
1.8
2.5
tpd @ Nom Voltage(Max)(ns)5.4
2.8
1.9
1.8
RoHSНе совместим
  • Simultaneous-Switching Performance of TI Logic Devices (Rev. B)
    PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
    Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
На английском языке: Datasheet Texas Instruments SN74AUC16244GQLR
