Datasheet Texas Instruments CD54HC151F3A — Даташит
СерияCD54HC151
МодельCD54HC151F3A
Высокоскоростной логический КМОП-мультиплексор с 8 входами, 16-CDIP от -55 до 125
CD54HC151, CD74HC151, CD54HCT151, CD74HCT151 datasheet
PDF, 445 Кб, Версия: C, Файл опубликован: 13 окт 2003
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC151F3A8412801EA
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Количество каналов1
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)43 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC151 (1)
  • CD54HC151F3A
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments CD54HC151F3A
