Datasheet Texas Instruments OPA2234U/2K5 — Даташит
СерияOPA2234
МодельOPA2234U/2K5
Маломощные прецизионные операционные усилители с однополярным питанием 8-SOIC от -40 до 85
OPA234, 2234, 4234: Low Power, Precision Single-Supply Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 10 апр 2008
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2234UOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)86 дБ
CMRR(Typ)106 дБ
GBW(Typ)0.35 МГц
Input Bias Current(Max)30000 pA
Iq per channel(Max)0.3 мА
Iq per channel(Typ)0.25 мА
Количество каналов2
Offset Drift(Typ)0.5 uV/C
Output Current(Typ)11 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.2 V/us
Vn at 1kHz(Typ)25 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.1 мВ
  • Tuning in Amplifiers
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2234U/2K5
