Datasheet ТI TPS54225PWPR — Даташит
| Серия | TPS54225 |
| Модель | TPS54225PWPR |
Входное напряжение от 4,5 В до 18 В, ток 2 А, синхронный понижающий преобразователь 14-HTSSOP от -40 до 85
4.5V to 18V Input, 2-A Synchronous Step-Down SWIFT(TM) Converter datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 14 фев 2011
- Understanding Thermal Dissipation and Design of a HeatsinkPDF, 59 Кб, Файл опубликован: 4 май 2011
Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu - D-CAP2 Frequency Response Model, based on frequency domain analysis of Fixed On-PDF, 681 Кб, Файл опубликован: 2 янв 2013
TPS542xx D-CAP2 Frequency Response Model, based on frequency domain analysis of Fixed On-Time with
Серия: TPS54225 (2)
- TPS54225PWP TPS54225PWPR
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
