Datasheet Texas Instruments SN65HVD11QDRG4 — Даташит
СерияSN65HVD11
МодельSN65HVD11QDRG4
Дифференциальный трансивер 3,3 В 8-SOIC от -40 до 125
SNx5HVD1x 3.3-V RS-485 Transceivers datasheet
PDF, 1.2 Мб, Версия: O, Файл опубликован: 1 фев 2017
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)1.25 | 1ku
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle
Open
Short
Fault Protection(V)-9 to 14
HBM ESD(kV)16
ICC(Max)(mA)15.5
IEC 61000-4-2 Contact(+/- kV)N/A
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Operating Temperature Range(C)-40 to 125
-40 to 85
Signaling Rate(Max)(Mbps)10
Supply Voltage(s)(Nom)(V)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • Device spacing on RS-485 buses
    PDF, 201 Кб, Файл опубликован: 18 апр 2006
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
  • Semiconductors > Interface > RS-485 Transceivers
На английском языке: Datasheet Texas Instruments SN65HVD11QDRG4
