Datasheet ТI ADS8381IPFBT — Даташит
| Серия | ADS8381 |
| Модель | ADS8381IPFBT |
18-битный параллельный АЦП 580KSPS 48-TQFP от -40 до 85
18-Bit, 580kHz, Unipolar Input, Micro Power Sampling Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 9 фев 2005
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8381 (2)
- ADS8381IBPFBT ADS8381IPFBT
