Datasheet ТI THS1041CPWRG4 — Даташит
| Серия | THS1041 |
| Модель | THS1041CPWRG4 |
10-разрядный АЦП малой мощности, 40 MSPS с PGA и внутренней прецизионной фиксацией 28-TSSOP от 0 до 70
10-Bit, 40-MSPS Analog-to-Digital Converter With PGA and Clamp (Rev. C)
PDF, 955 Кб, Версия: C, Файл опубликован: 28 окт 2004
- High-Speed ADC THS1041and FPGA Interface ConsiderationsPDF, 130 Кб, Файл опубликован: 15 мар 2007
The Texas Instruments THS1041 is a 10-bit, 40-MSPS, high-speed analog-to-digital converter (ADC). For many years because of its low power dissipation and extended life, it has been used in various app - Clamp function of high-speed ADC THS1041PDF, 235 Кб, Файл опубликован: 10 окт 2006
- CDCE62005 as Clock Solution for High-Speed ADCsPDF, 805 Кб, Файл опубликован: 4 сен 2008
TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527, which is capable of sampling up to 210 MSPS. To realize the full potential of thes - Smart Selection of ADC/DAC Enables Better Design of Software-Defined RadioPDF, 376 Кб, Файл опубликован: 28 апр 2009
This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs - Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the refe - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed, high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483, which is capable of - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
As system bandwidths have increased, an accurate estimate of the noise contribution for each element in the signal channel has become increasingly important. Many designers are not, however, particula
Серия: THS1041 (8)
- THS1041CDW THS1041CPW THS1041CPWG4 THS1041CPWR THS1041CPWRG4 THS1041IDW THS1041IPW THS1041IPWG4
- Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
