Datasheet Texas Instruments SN74HC191N — Даташит
Серия | SN74HC191 |
Модель | SN74HC191N |
4-битные синхронные двоичные счетчики прямого/обратного хода 16-PDIP от -40 до 85
SN54HC191, SN74HC191 datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 2 окт 2003
![]() 59 предложений от 26 поставщиков Микросхема Логический контроллер, TEXAS INSTRUMENTS SN74HC191N Binary Synchronous Up / Down Counter, HC Family, 48MHz, 2V to 6V, DIP-16 | |||
SN74HC191N3 Texas Instruments | 11 ₽ | ||
SN74HC191N Texas Instruments | 18 ₽ | ||
SN74HC191N Texas Instruments | по запросу | ||
SN74HC191NS Texas Instruments | по запросу |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | SN74HC191N |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 28 Mhz |
Function | Counter |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Technology Family | HC |
Тип | Binary |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 41 нс |
Бессвинцовая технология (Pb Free) | Да |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC191 (9)
- Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
