Datasheet Texas Instruments UCC28250PW — Даташит
СерияUCC28250
МодельUCC28250PW
Усовершенствованный ШИМ-контроллер с операцией предварительного смещения 20-TSSOP от -40 до 125
UCC28250 Advanced PWM Controller With Prebias Operation datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 28 июн 2015
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаUCC28250
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Control MethodCurrent,Voltage
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Frequency(Min)40 kHz
Gate Drive(Typ)0.2 A
Package GroupTSSOP
Special FeaturesHV Start-up
TopologyForward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off4.3/4.1 В
Vin(Max)20 В
Vin(Min)4.3 В
  • Evaluation Modules & Boards: UCC28250EVM-564
    Evaluation Module for UCC28250 Adv.PWM Controller w/ Pre-biased Load Op. on Secondary Side Control
  • Evaluation Modules & Boards: UCC28250EVM-501
    Evaluation Module for UCC28250 Advanced PWM Controller on Primary Side Control
  • Designing UCC28250 as a Secondary Side Control with a Pre-Bias Condition
    PDF, 395 Кб, Файл опубликован: 24 ноя 2010
    This application note addresses the considerations for using the UCC28250 as a secondary side controller. With voltage mode control, the UCC28250 can be used in a design that produces smooth turn-on performance with an output pre-bias condition. The design guidelines are summarized from various performance tests and examined particularly on a 100-W, dc-dc half bridge converter. This converter is d
  • Differences Between the UCC28251 and UCC28250 and Evaluation of the UCC28251 in (Rev. A)
    PDF, 36 Кб, Версия: A, Файл опубликован: 15 фев 2013
    The UCC28251 is a functional variant of the UCC28250 PWM Controller. While the same basic functionality of the UCC28250 is largely maintained, the UCC28251 is designed to operate at a lower frequency (minimum of 27 kHz when programmed by RT pin) allowing operation in 400-V input DC-to-DC converters in off-line AC-to-DC power supplies, where frequency-dependent high-voltage switching lossesare an
Серия: UCC28250 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC28250PW
