Datasheet Texas Instruments UCC25702PW — Даташит
СерияUCC25702
МодельUCC25702PW
Расширенный широтно-импульсный модулятор с режимом напряжения 14-TSSOP от -40 до 85
Advanced Voltage Mode Pulse Width Modulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 17 июн 2005
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY90
Маркировка25702
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Control MethodFeedforward,Voltage
Duty Cycle(Max)99 %
Frequency(Max)700 kHz
Gate Drive(Typ)1 A
Package GroupTSSOP
Special FeaturesMulti-topology,Soft Start,Synchronization Pin
TopologyBoost,Flyback,Forward
UVLO Thresholds On/Off9.9/9.1 В
Vin(Max)400 В
Vin(Min)9.9 В
  • U-150 Applying the UCC3570 Voltage-Mode PWM Controller to Both Off-Line
    PDF, 568 Кб, Файл опубликован: 5 сен 1999
    The UCC3570 families of pulse-width modulators are for application in isolated switching supplies using primary-side control and a voltage-mode feedback loop. BiCMOS processing provides higher switching frequencies at lower quiescent current drain, while including innovations in both performance and protection features. Its versatility is demonstrated with the description of a 50W, wide input-volt
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC25702PW
