Datasheet Texas Instruments TLV2462IDGKG4 — Даташит
СерияTLV2462
МодельTLV2462IDGKG4
Двойной маломощный операционный усилитель ввода/вывода с Rail-to-Rail 8-VSSOP от -40 до 125
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
Package TypeDGK
Industry STD TermVSSOP
Package QTY80
МаркировкаAAJ
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)71 дБ
CMRR(Typ)85 дБ
GBW(Typ)6.4 МГц
Input Bias Current(Max)14000 pA
Iq per channel(Max)0.65 мА
Iq per channel(Typ)0.55 мА
Количество каналов2
Offset Drift(Typ)2 uV/C
Рабочий диапазон температурот -40 до 125,0 до 70 C
Output Current(Typ)80 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)1.6 V/us
Total Supply Voltage(Max)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)11 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluating the TLV2462 and TLV2772 as Drive Amps for the TLV2544/TLV2548 ADC
    PDF, 63 Кб, Файл опубликован: 26 июн 2000
    This report presents a method for comparing the ac performance of the TLV2462 and TLV2772 operational amplifiers to the ac performance of the TLV2544/TLV2548 analog-to-digital converter.
  • Using the TLV246x as a Multiplexer with Gain in a Data Acquisition System
    PDF, 62 Кб, Файл опубликован: 14 дек 1998
    Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters.
  • TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
На английском языке: Datasheet Texas Instruments TLV2462IDGKG4
