Datasheet Texas Instruments THS6042CDDAG3 — Даташит
СерияTHS6042
МодельTHS6042CDDAG3
Драйвер линии ADSL CPE, 350 мА, +/-12 В 8-SO PowerPAD 0–70
350 mA +/-12V ADSL CPE Line Drivers datasheet
PDF, 1.6 Мб, Версия: G, Файл опубликован: 11 дек 2001
Package TypeDDA
Industry STD TermHSOIC
Package QTY75
Маркировка6042C
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
2nd Harmonic67 dBc
3rd Harmonic96 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl120 МГц
CMRR(Min)59 дБ
CMRR(Typ)68 дБ
GBW(Typ)120 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)10.5 мА
Iq per channel(Typ)8.2 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)350 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)1400 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2.4 нВ/rtГц
Vn at Flatband(Typ)2.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)16 мВ
  • Evaluation Modules & Boards: THS6042EVM
    THS6042 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
Серия: THS6042 (5)
На английском языке: Datasheet Texas Instruments THS6042CDDAG3
