Datasheet Texas Instruments ADC08D1520WGFQV — Даташит
СерияADC08D1520QML-SP
МодельADC08D1520WGFQV
ADC08D1520QML Low Power, 8-Bit, Dual 1.5 GSPS or Single 3.0 GSPS A/D Converter datasheet
PDF, 1.2 Мб, Версия: O, Файл опубликован: 19 мар 2013
Микросхема Преобразователь AD, 8Bit, Dual 1.5GSPS or Single 3GSPS, Analog-to-Digital Converter (ADC) 128-CFP -55 to 125
ADC08D1520WGFQV
995 642 ₽
ADC08D1520WGFQV
995 642 ₽
ADC08D1520WGFQV
1 115 119 ₽
ADC08D1520WGFQV
Pin128128
Package TypeNBCNBC
Industry STD TermCFPCFP
JEDEC CodeS-CQFP-GS-CQFP-G
Package QTY1212
МаркировкаADC08D1520WGFQV5962F0721401VZC Q
Width (мм)19.55819.558
Length (мм)19.55819.558
Thickness (мм)2.9972.997
Pitch (мм).508.508
Max Height (мм)3.5563.556
# Input Channels2,1
Analog Voltage AVDD(Max)2.2 В
Analog Voltage AVDD(Min)1.8 В
АрхитектураFolding Interpolating
ENOB7.4 Bits
INL(Max)6 +/-LSB
INL(Typ)0.3 +/-LSB
InterfaceParallel LVDS
Рабочий диапазон температурот -55 до 125,25 C
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)2000 mW
RatingSpace
Reference ModeInt
Разрешение8 Bits
SFDR55.5 дБ
SNR47 дБ
Sample Rate (max)3GSPS SPS
  • AN-1558 Clocking High-Speed A/D Converters (Rev. B)
    PDF, 1.2 Мб, Версия: B, Файл опубликован: 1 май 2013
    Extremely high-speed ADCs (>1 GSPS) demand a low-jitter sample clock in order to preserve signal-tonoiseratio (SNR). These 8- and 10-bit converters have best-case noise floors set by quantization noise.For an N-bit ADC sampling a full-scale sinusoid, the well known expression for SNR (in dB) is: SNR =6.02N + 1.76. This sets the best case noise floor for an 8-bit ADC at в€’49.9 dBc. The noise f
Серия: ADC08D1520QML-SP (3)
  • Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
На английском языке: Datasheet Texas Instruments ADC08D1520WGFQV
