Datasheet Texas Instruments TPS60251RTWT — Даташит
СерияTPS60251
МодельTPS60251RTWT
Высокоэффективный зарядовый насос для 7 светодиодов WLED с интерфейсом I2C 24-WQFN от -40 до 85
High Efficiency Charge Pump for 7 WLEDs with I2C Interface datasheet
PDF, 901 Кб, Версия: C, Файл опубликован: 6 ноя 2007
Pin242424
Package TypeRTWRTWRTW
Industry STD TermWQFNWQFNWQFN
JEDEC CodeS-PQFP-NS-PQFP-NS-PQFP-N
Package QTY250250250
CarrierSMALL T&RSMALL T&RSMALL T&R
МаркировкаTPS60251TPS60251
Width (мм)444
Length (мм)444
Thickness (мм).75.75.75
Pitch (мм).5.5.5
Max Height (мм).8.8.8
Количество каналов7
Duty Cycle(Max)0.23 %
LED4+2+1
LED Current Per Channel25 мА
Package GroupWQFN
Package Size: mm2:W x L24WQFN: 16 mm2: 4 x 4(WQFN) PKG
Peak Efficiency93 %
Shutdown Current(Typ)0.1 uA
Special FeaturesAnalog Dimming,Enable/Shutdown,Fault Detection,I2C Control,Integrated Switch,Load Disconnect During Shutdown,OVP,Soft Start,Synchronous Rectification
Switching Frequency(Max)875 kHz
TopologyBoost
ТипCapacitive
Vin(Max)6 В
Vin(Min)3 В
Vout(Max)6.5 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS60251EVM-192
    TPS60251 Evaluation Module
  • Ballast Resistor Calculation – Current Matching in Parallel LEDs
    PDF, 351 Кб, Файл опубликован: 16 апр 2009
    Engineers often need to connect LEDs in parallel. Ideally, the LEDs share current equally. In reality, even LEDs from the same production lot have poorly matched I-V characteristics. This mismatch causes the LEDs to not share the current equally. The engineer can add a ballast resistor in series with each LED to minimize current differences. This application report explains how to size the ball
Серия: TPS60251 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS60251RTWT
