Datasheet Texas Instruments TRF3761-AIRHAR — Даташит
СерияTRF3761-A
МодельTRF3761-AIRHAR
Малошумный синтезатор частоты PLL целого числа n со встроенным ГУН 40-VQFN от -40 до 85
TRF3761-x Integer-N PLL with Integrated VCO datasheet
PDF, 2.5 Мб, Версия: K, Файл опубликован: 31 дек 2015
Pin4040
Package TypeRHARHA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаTRF3761-A
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Current Consumption130 мА
Integrated VCOYes
Lock Time(Typ)>350 us
Normalized PLL Phase Noise-137 dBc/Hz
Output Frequency(Max)1608 МГц
Output Frequency(Min)1493 МГц
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
Special FeaturesIntegrated VCO
VCC4.5 to 5.25 В
VCO Phase Noise(Nom)-136 dBc/Hz
  • TRF3761 QFN Installation Using a Hakko Hot Air Rework Station
    PDF, 38 Кб, Файл опубликован: 7 апр 2007
    The TRF3761 devices are typically sampled separately from the board provided. This guideline is designed to help the user evaluating these parts install the sample device.
  • Fractional/Integer-N PLL Basics
    PDF, 6.7 Мб, Файл опубликован: 13 май 1998
    Phase Locked Loop (PLL) is a fundamental part of radio, wireless and telecommunication technology. The goal of this document is to review the theory, design and analysis of PLL circuits. PLL is a simple negative feedback architecture that allows economic multiplication of crystal frequencies by large variable numbers. By studying the loop components and their reaction to various noise sources, we
Серия: TRF3761-A (2)
  • Semiconductors > Clock and Timing > RF PLLs and Synthesizers
TRF3761AIRHAR, TRF3761 AIRHAR
На английском языке: Datasheet Texas Instruments TRF3761-AIRHAR
