Datasheet Texas Instruments LMV934MAX — Даташит
СерияLMV934-N
МодельLMV934MAX
Операционные усилители Quad 1,8 В, RRIO 14-SOIC от -40 до 125
LMV93x-N Single, Dual, Quad 1.8-V, RRIO Operational Amplifiers datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 7 май 2017
Pin14
Package TypeD
МаркировкаLMV934MA
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementLMV934MAX/NOPB
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)0.60 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)60
CMRR(Typ)(dB)86
GBW(Typ)(MHz)1.5
Input Bias Current(Max)(pA)35000
Iq per channel(Max)(mA)0.23
Iq per channel(Typ)(mA)0.116
Number of Channels(#)4
Offset Drift(Typ)(uV/C)5.5
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)65
Package Size: mm2:W x L (PKG)14SOIC: 52 mm2: 6 x 8.65(SOIC)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)0.42
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)1.8
Vn at 1kHz(Typ)(nV/rtHz)50
Vos (Offset Voltage @ 25C)(Max)(mV)5.5
RoHSНе совместим
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMV934MAX
