Datasheet Texas Instruments CD74HC153M96 — Даташит
| Серия | CD74HC153 |
| Модель | CD74HC153M96 |
Высокоскоростные КМОП-логические двойные мультиплексоры с 4 входами 16-SOIC от -55 до 125
CD54HC153, CD74HC153, CD54HCT153, CD74HCT153 datasheet
PDF, 443 Кб, Версия: C, Файл опубликован: 13 окт 2003
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | HC153M |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Полоса частот | 28 МГц |
| Bits | 4 |
| Количество каналов | 2 |
| Configuration | 4:1 |
| Digital input leakage(Max) | 5 uA |
| ESD Charged Device Model | 0.75 kV |
| ESD HBM | 2 kV |
| F @ Nom Voltage(Max) | 28 Mhz |
| Function | Encoder/Multiplexer |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | HC |
| Тип | Standard |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| Voltage(Nom) | 3.3,5 В |
| tpd @ Nom Voltage(Max) | 40 нс |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC153 (5)
- CD74HC153E CD74HC153EE4 CD74HC153M CD74HC153M96 CD74HC153MG4
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
