Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC3825AQ — Даташит
СерияUC3825A
МодельUC3825AQ
Высокоскоростной ШИМ-контроллер 20-PLCC от 0 до 70
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Pin20
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Package QTY46
МаркировкаUC3825AQ
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.06
Max Height (мм)4.57
Control MethodCurrent,Voltage
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Gate Drive(Typ)2 A
Package GroupPDIP,SOIC
Special FeaturesError Amplifier,Leading Edge Blanking,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)22 В
Vin(Min)8.4 В
  • U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM Controllers
    PDF, 204 Кб, Файл опубликован: 5 сен 1999
    The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3825AQ
