Datasheet Texas Instruments LM393PSRG4 — Даташит
| Серия | LM393 |
| Модель | LM393PSRG4 |
Двойной дифференциальный компаратор 8-SO от 0 до 70
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
Купить LM393PSRG4 на РадиоЛоцман.Цены — от 6.19 до 147 ₽16 предложений от 13 поставщиков IC COMPARATOR DUAL DIFF 8SO. Comparator Differential CMOS, MOS, Open-Drain, TTL 8-SO. Linear - Comparators | |||
| LM393PSRG4 Texas Instruments | 6.19 ₽ | ||
| LM393PSRG4 Texas Instruments | от 31 ₽ | ||
| LM393PSRG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | PS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | L393 |
| Width (мм) | 5.3 |
| Length (мм) | 6.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Input Bias Current (+/-)(Max) | 50 нА |
| Iq per channel(Max) | 0.5 мА |
| Количество каналов | 2 |
| Рабочий диапазон температур | от 0 до 70 C |
| Тип выхода | Open Collector |
| Package Group | SO |
| Package Size: mm2:W x L | 8SO: 48 mm2: 7.8 x 6.2(SO) PKG |
| Propagation Delay Time | 0.3 uS |
| Rail-to-Rail | Out |
| Rating | Catalog |
| Special Features | N/A |
| VICR(Max) | 34.5 В |
| Vos (Offset Voltage @ 25C)(Max) | 5 мВ |
| Vs(Max) | 36 В |
| Vs(Min) | 2 В |
- Designing Overcurrent protection for TPL7407L Peripheral DriverPDF, 177 Кб, Файл опубликован: 5 ноя 2014
Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
Серия: LM393 (21)
- Semiconductors > Amplifiers > Comparators
