Datasheet Texas Instruments THS3111IDG4 — Даташит
СерияTHS3111
МодельTHS3111IDG4
Одиночный малошумящий высоковольтный усилитель с токовой обратной связью 8-SOIC от -40 до 85
Low-Noise, High-Voltage, Current-Feedback Op Amplifiers datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 12 окт 2009
Package TypeD
Package QTY75
Маркировка3111I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic52 dBc
3rd Harmonic48 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Current FB
BW @ Acl100 МГц
CMRR(Min)62 дБ
CMRR(Typ)68 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)4000000 pA
Iq per channel(Max)6.5 мА
Iq per channel(Typ)4.8 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)260 мА
Rail-to-RailNo
Slew Rate(Typ)900 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3 нВ/rtГц
Vn at Flatband(Typ)3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: THS3111EVM
    THS3111 Evaluation Module
  • Evaluation Modules & Boards: THS3121EVM
    THS3121 Evaluation Module
  • Evaluation Modules & Boards: THS3120EVM
    THS3120 Evaluation Module
  • Evaluation Modules & Boards: THS3110EVM
    THS3110 Evaluation Module
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS3111IDG4
