Оптопары и оптореле Megawin
Datasheet Texas Instruments SN65HVD05D — Даташит
СерияSN65HVD05
МодельSN65HVD05D
Высокопроизводительный трансивер RS-485 8-SOIC от -40 до 85
High-Output RS-485 Transceivers datasheet
PDF, 513 Кб, Версия: E, Файл опубликован: 13 авг 2009
Package TypeD
Package QTY75
МаркировкаVP05
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-9 to 14 В
HBM ESD16 kV
ICC(Max)15 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes64
Signaling Rate(Max)40 Mbps
Supply Voltage(s)(Nom)5 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • Operating RS-485 Transceivers at Fast Signaling Rates
    PDF, 631 Кб, Файл опубликован: 15 ноя 2004
    The TIA/EIA-485-A standard specifies characteristics for RS-485 signaling. Most applications operate below 10 Mbps but it is often possible to signal at higher rates. This application report examines the constraints on high-speed signaling and presents results using the SN65HVD10 transceiver as one example transceiver. Our method is to measure the eye patterns at the end of a 10-m cable under vary
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD05D
