Datasheet Texas Instruments THS4500CDGKRG4 — Даташит
СерияTHS4500
МодельTHS4500CDGKRG4
Высокоскоростной полностью дифференциальный усилитель, +/-5 В, 8-VSSOP, от 0 до 70
Wideband, Low-Distortion, Fully Differential Amplifiers. datasheet
PDF, 1.6 Мб, Версия: F, Файл опубликован: 7 ноя 2011
IC OPAMP DIFF 1 CIRCUIT 8VSSOP. Differential Amplifier 1 Circuit Differential 8-VSSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
THS4500CDGKRG4
64 ₽
THS4500CDGKRG4
442 ₽
THS4500CDGKRG4
442 ₽
THS4500CDGKRG4
Package TypeDGK
Industry STD TermVSSOP
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic(dBc)82
3rd Harmonic(dBc)97
@ MHz8
Acl, min spec gain(V/V)1
Additional FeaturesShutdown
Approx. Price (US$)3.98 | 1ku
АрхитектураFully Differential
BW @ Acl(MHz)370
CMRR(Min)(dB)74
CMRR(Typ)(dB)80
GBW(Typ)(MHz)300
Input Bias Current(Max)(pA)4600000
Iq per channel(Max)(mA)28
Iq per channel(Typ)(mA)23
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)120
Package GroupVSSOP
Package Size: mm2:W x L (PKG)See datasheet (SON)
Rail-to-RailIn to V-
Slew Rate(Typ)(V/us)2800
Total Supply Voltage(Max)(+5V=5, +/-5V=10)15
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4.5
Vn at Flatband(Typ)(nV/rtHz)7
Vos (Offset Voltage @ 25C)(Max)(mV)7
RoHSНе совместим
  • Evaluation Modules & Boards: THS4500EVM
    THS4500EVM Evaluation Module
  • Evaluation Modules & Boards: THS7530EVM
    THS7530 Evaluation Module
На английском языке: Datasheet Texas Instruments THS4500CDGKRG4
