Datasheet Texas Instruments MSP430F5335IZQWT — Даташит
| Серия | MSP430F5335 |
| Модель | MSP430F5335IZQWT |
MSP430F533x Микроконтроллер смешанных сигналов 113-BGA MICROSTAR JUNIOR -40–85
MSP430F533x Mixed-Signal Microcontrollers datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 8 дек 2015
|  Купить MSP430F5335IZQWT на РадиоЛоцман.Цены — от 251 до 688 ₽ 9 предложений от 9 поставщиков IC MCU 16BIT 256KB FLASH 113BGA. CPUXV2 MSP430F5xx Microcontroller IC 16-Bit 20MHz 256KB (256K x 8) FLASH 113-BGA Microstar Junior (7x7).... | |||
| MSP430F5335IZQWT Texas Instruments | 251 ₽ | ||
| MSP430F5335IZQWT Texas Instruments | 422 ₽ | ||
| MSP430F5335IZQWT Texas Instruments | 468 ₽ | ||
| MSP430F5335IZQWT Texas Instruments | по запросу | ||
| Pin | 113 |
| Package Type | ZQW |
| Industry STD Term | BGA MICROSTAR JUNIOR |
| JEDEC Code | S-PBGA-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | M430F5335 |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | .74 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| ADC | ADC12 - 12ch |
| AES | N/A |
| Active Power | 330 uA/MHz |
| Additional Features | Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA |
| BSL | UART |
| CPU | MSP430 |
| Comparators | 12 |
| DMA | 6 |
| Featured | f5 |
| Тактовая частота | 20 МГц |
| GPIO Pins | 74 |
| I2C | 2 |
| Max VCC | 3.6 |
| Min VCC | 1.8 |
| Multiplier | 32x32 |
| Non-volatile Memory | 256 KB |
| Package Group | BGA MICROSTAR JUNIOR |
| Package Size: mm2:W x L | 113BGA MICROSTAR JUNIOR: 49 mm2: 7 x 7(BGA MICROSTAR JUNIOR) PKG |
| RAM | 18 KB |
| Rating | Catalog |
| SPI | 4 |
| Special I/O | N/A |
| Standby Power | 2.2 LPM3-uA |
| Timers - 16-bit | 4 |
| UART | 2 |
| Wakeup Time | 3 us |
- Evaluation Modules & Boards: MSP-FET430U100C
 100-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F5x and MSP430F6x MCUs
- Evaluation Modules & Boards: MSP-TS430PZ100C
 MSP-TS430PZ100C - 100-pin Target Development Board for MSP430F5x and MSP430F6x MCUs
- JTAG Emulators/ Analyzers: ENERGYTRACE
 MSP EnergyTrace Technology
- Using the MSP430 Timer_D Module in Hi-Resolution ModePDF, 870 Кб, Файл опубликован: 2 окт 2013
 This application report describes the use of the high-resolution feature of the Timer_D module introduced in MSP430F51x1 and MSP430F51x2 devices. Timer_D enables applications that require high resolution such as capacitive touch detection, PWM DACs, advanced LED lighting, and digital controllers for power supplies. This application report provides an advanced description of the use and calibration
- Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
 This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
- General Oversampling of MSP ADCs for Higher Resolution (Rev. A)PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
 Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
- MSP Code Protection FeaturesPDF, 752 Кб, Файл опубликован: 7 дек 2015
 MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
- Design Considerations When Using the MSP430 Graphics LibraryPDF, 475 Кб, Файл опубликован: 5 окт 2012
 LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
- ESD Diode Current SpecificationPDF, 520 Кб, Файл опубликован: 7 дек 2015
 This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
Серия: MSP430F5335 (4)
- MSP430F5335IPZ MSP430F5335IPZR MSP430F5335IZQWR MSP430F5335IZQWT
- Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
