Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI ADS8412IBPFBT — Даташит
СерияADS8412
МодельADS8412IBPFBT
Datasheet Texas Instruments ADS8412IBPFBT
16-разрядный параллельный АЦП со скоростью 2 MSPS с опорным сигналом, униполярный полностью дифференциальный вход 48-TQFP от -40 до 85
16-Bit 2 MSPS Unipolar Diff Input Micropower Sampling Analog-to-Digital Convert datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 20 дек 2004
  • Using ADS8411/2 (16-Bit 2MSPS SAR) as a Serial ADC
    PDF, 438 Кб, Файл опубликован: 24 май 2004
    This application report discusses how to use a parallel ADC as a serial ADC by using a low-cost CPLD. This concept is tested with a Texas Instruments ADS8411/12 (16-bit, 2 MSPS SAR ADC) and an Altera(TM) MAX 3000A CPLD. A full solution with a schematic, layout, and software for programming the CPLD is presented at the end of the report.
  • Interfacing the ADS8402/ADS8412 to TMS320C6713 DSP
    PDF, 262 Кб, Файл опубликован: 23 сен 2004
    This application report presents a solution for interfacing the ADS8402 and ADS8412 16-bit, parallel interface converters to the TMS320C6713 DSP. The hardware solution consists of existing and orderable hardware, specifically the ADS8402EVM, 'C6713 DSK, and 5-6K interface board. The software demonstrates how to use the EDMA controller to efficiently collect data from the data converter. Discussed
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
Серия: ADS8412 (4)
На английском языке: Datasheet Texas Instruments ADS8412IBPFBT
Политика конфиденциальности
