Datasheet Texas Instruments SN74AS1034AN — Даташит
СерияSN74AS1034A
МодельSN74AS1034AN
Шестнадцатеричные драйверы 14-PDIP от 0 до 70
Hex Drivers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 1 янв 1995
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаSN74AS1034AN
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.014 мА
Output Drive (IOL/IOH)(Max)-48/48 мА
Package GroupPDIP
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)6 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
На английском языке: Datasheet Texas Instruments SN74AS1034AN
