Datasheet Texas Instruments TL751L12QDR — Даташит
| Серия | TL751L12 |
| Модель | TL751L12QDR |
LDO с одним выходом, 150 мА, фиксированный (12,0 В), низкий ток покоя, защита от сброса нагрузки 60 В, 8-SOIC от -40 до 125
Datasheet
Fixed Positive LDO Regulator, 12V, 0.6V Dropout, BIPolar, PDSO8 | |||
| TL751L12QDR Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Accuracy(%) | 4 |
| Additional Features | Enable Overcurrent Protection Thermal Shutdown |
| Approx. Price (US$) | 0.20 | 1ku |
| Fixed Output Options(V) | 12 |
| Iq(Typ)(mA) | 1 |
| Operating Temperature Range(C) | 0 to 125 |
| Output Capacitor Type | Cap Free Non-Ceramic |
| Output Options | Fixed Output |
| Package Group | SOIC |
| Package Size: mm2:W x L (PKG) | See datasheet (PDIP) See datasheet (CDIP) |
| Rating | Catalog |
| Vdo(Typ)(mV) | 600 |
| Vin(Max)(V) | 26 |
| Vin(Min)(V) | 13 |
| Vout(Max)(V) | 12 |
| Vout(Min)(V) | 12 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL751L12 (6)
- TL751L12CP TL751L12MFKB TL751L12MJGB TL751L12QD TL751L12QDR TL751L12QP
