Datasheet Texas Instruments F28M36H53C2ZWTT — Даташит
СерияF28M36H53C2
МодельF28M36H53C2ZWTT
Концертный микроконтроллер 289-NFBGA от -40 до 105
F28M36x Concerto Microcontrollers datasheet
PDF, 2.2 Мб, Версия: D, Файл опубликован: 29 окт 2015
Pin289289
Package TypeZWTZWT
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY9090
МаркировкаF28M36H53C2ZWTT
Width (мм)1616
Length (мм)1616
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
# of ADC Modules1
12-bit A/D24 #Channels
ADC Channels24
ADC Conversion Time350 нс
ADC Resolution12-bit
ADC Sample & HoldDual
CAN2
CPUC28x, Cortex-M3
DMA1 6-Ch DMA, 1 32-ch DMA Ch
EMIFYes
Ethernet1
FPUYes
Flash1024 KB
Тактовая частота150,100 МГц
GPIO124
Generation28x + ARM Cortex M3 Concerto Series
I2C3
IO Supply3.3 В
McBSP1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM24 Ch
Package GroupNFBGA
Package Size: mm2:W x L289NFBGA: 256 mm2: 16 x 16(NFBGA) PKG
RAM232 KB
RISC Frequency75,100 МГц
SPI5
Timers3 32-Bit CPU,2 WD
Total On-Chip Memory1256 KB
Total Serial Ports2 CANs,3 I2C,5 SPI,6 SCIs,1 McBSP,1 USB,1 Ethernet
UART6
USB1
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • Evaluation Modules & Boards: TMDSCNCD28M36
    F28M36 Concerto Control Card
  • Evaluation Modules & Boards: TMDSADAP180TO100
    180 to 100 Pin DIMM Adapter
  • Evaluation Modules & Boards: TMDSDOCK28M36
    H63C2 Concerto Experimenter Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
Серия: F28M36H53C2 (2)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > F28M3x
На английском языке: Datasheet Texas Instruments F28M36H53C2ZWTT
